Help w/SubZero Condenser Cleaning
Posted by Fun2BHere (My Page) on
Mon, Jul 30, 12 at 13:13
I have an old SubZero side-by-side with the condenser on top. I clean the condenser monthly with a soft brush and a vacuum. Recently when I was having problems keeping the unit at cold enough temps, I had a service person come out. He cleaned the condenser with water and mentioned that sometimes a brush and vacuum don't get it clean enough.
My question is...should I try to clean the unit with water every other month or so? If I do, will the unit rust as there's no way to get it completely dry?
Thanks in advance for your help.
RE: Help w/SubZero Condenser Cleaning
Honestly I'd call Sub Zero and ask them. Their customer service is fantastic.
I have a 501 R and 501 F that are nearly 28 years old and I've only used an appliance brush and vacuum. None of the service techs have ever mentioned using water.
According to "what seemed to me" a "Knowledgeable former poster here, He claimed that some of the "Copper Problems" that SZ had with "Evaporators, not Condensers, as I recall, was due to the use of 2 metals, copper tubing with aluminum fins and yes moisture, particularly the kind near the sea shore, exacerbated the oxidation of the copper coils, but as I mentioned, as far as I had read, that was the evaporator coils not the condenser coils--- BUT-- as the other poster here said, "Check with SZ", better safe than sorry!
Good luck with it!
Gary
Thanks for your replies. I will call SubZero before I start cleaning with water.
