Recommendations for Water Filter
rosewest (
Fri, Jul 6, 12 at 2:46
| Anyone have recommendations on whole house filters and drinking water purifiers at the kitchen sink??
Thanks in advance
Rosewest |
RE: Recommendations for Water Filter
| Our plumber installed an Aqua Pure whole house filter on the cold water line going to the kitchen when we did our reno. This filter "services" the water line to the fridge, the faucet at our sink, the pot filler faucet, and the added-post-reno outside faucet "on" our deck (plumber tapped into the line under the sink after we did the reno, so our flowers and herbs get filtered water by default!). We replace the filters every 6 months; spring and fall. |
| We just installed an Everpure PBS-400 filter for drinking water...what's nice about the PBS-400 is that it has a 2.2gpm flow rate, so it doesn't slow things down like many other options, and you can fill pitchers, etc, fast. Although our kitchen is still *far* from finished, I have already been drinking the filtered water for about a week. Tastes great, seems to work great, no complaints so far. Based on the specs and our limited expeience so far, I would recommend it. |
Echo?
| Okay, that's weird. Sorry for the double post! |
Echo?
| It might help to post where you live and what type of water you currently have (City, well, hard, soft, etc.). My wife and I just decided to get a water ionizer as she has always had tons of problems with her stomach and we are hoping this will help some. IT also has 2 built in filters as well as an additional external filter. You can build your own water filter and configure it specifically for what you want/need for your situation rather than going with something generic. Though, in most cases, the generic will do probably 95% of what most people require, but again that depends on your situation. |
| We also have the Everpure PBS-400 filter on the cold water line of our prep sink faucet and the cold water line of our master bath sink faucet, so we can easily get filtered water in our bathroom. With the 2.2GPM flow rate we didn't need to drill an extra hole in the counter and put another faucet in for filtered water -- we always know we can get filtered water from the prep sink or bathroom sink tap. We don't wash dishes in the prep sink. The filters last about a year and cost $82 for a replacement from Amazon. Billy |
| We are building outside the Portland OR area on a small acreage with a well. The well is currently contaminated with e coli and will need to be treated. It's been recommended that we get a water purifier/filter once the well's been treated. I think I will prefer a whole house system...The house will be finished in a month so we'll want to get something lined up soon. |
| I use a reverse osmosis system mainly sourced by SpectraPure for the key control parts. It uses a peristaltic pump run by the effluent flow to store RO water at about the same pressure as I regulate it for input to the RO membranes. I also use two RO membranes in series (brine wise) to get a higher yield of RO water from a given amount of input water. Production rate capability is about 6 gal/hr. The RO water is plumbed to three sinks, a refrigerator ice maker, and to a centrifugal humidifier. I find this "tasteless" water to be ideal for tea, ice, orchid watering, and dust free humidification. It is also used for most cooking that would normally use tap water. kas |
| Rose, if you want to be extra safe I know there are also UV options that you can add to filters that will kill off most nasty things in water in addition to the filtration. Sounds like a whole house might be your best bet based upon what you have. Also, did you test for hard water from your well, do you need a softner as well? |
| Oooppssss----I meant to say the well is infected with coliform, not e coli!! I don't know if it was tested for hard water---the report did come back saying it is high in iron---that sounds pretty hard and wonder if it would stain clothing in the wash??? We'll need to test it again after the coliform's been treated so I'll ask to have it tested for hard water at that time. This is all very new to me---never owned a well before! So thank you everyone for your recommendations. I'll have to get a little more info on the water. |
You need to have a comprehensive water test done before purchasing any filter. Contact your county environmental health department for testing procedures. I also suggest you head over to the plumbing forum and start asking questions there. If you are on a well, it is likely that you have hard water and iron among other things. If untreated you WILL have iron staining on hour close, sinks, tubs etc. You have to know what is in your water before deciding the best method of treatment. |
| Thank you, ribs. I'll check out the plumbing forum (didn't know there was one). We did have a comprehensive water test done----I'll go find the report and head over to plumbing and see what they have to say about it. We will treat the well as the water testing lab and the well company have recommended, then we'll follow up with an appropriate water purifier when I find out what that will be.. |
| we use the Kinetico K5 for our well water. Love it! We also have their softener for the house...it's going on 30 years old and still going strong! Great investment!! |
| I just read your info about high iron--we have it too. we have a whole house softener, with an extra iron filer..called a smart choice...no more staining or rotten egg smell! |
| Thank you Christine. Home Depot sells the Kinetico and will test your water as well. Will check it out... |
| I have the Aquasana water filter and it works just fine. The cartridge last for 500 gallons without any problems. My water is cleaner and better than before. |
| A water filter with UV+RO technology would be best. These are in more demand as compared to single technology water filters. |
