| I have seen comments on this Forum about refrigerators with Dual Compressors and/or Dual Evaporators. These are good to have? Or are they must-haves? Is it just an odor-tranference issue? Or, what are the functions of Dual Compressors and Dual Evaporators? Which fridges have them? Lots o' questions, but I know you guys know the answers! TIA. |
| The evaporator is the cooling coil. A single compressor / single evaporator unit has the evaporator in the freezer section, with a circulation fan in there and a duct that blows a portion of the air into the refrigerator section to cool it. Air and moisture is obviously mixed between the two sections and temperature control is not as precise. The thermostat is typically in the refrigerator section and an air damper adjustment roughly adjusts the freezer section per how much of the air is sent to the refrigerator section. Dual evaporators allows more precise control of temperature in each section. A single compressor / dual evaporator unit has a separate evaporator and circulation fan in each section, with a single compressor running both coils. A diverter valve controls whether one or the other coil, or both, are active at any given time by routing the refrigerant (Freon) accordingly. A dual compressor / dual evaporator unit has completely independent refrigeration systems for each section. |
| SZ "was probably" the first to use to Dual compressors and Dual evaporators. The SZ is actually a separate Fridge and Freezer built into the same cabinet. Some folks, (and of course SZ marketing),claim that this eliminates the "Odor-transference issue", but being here on Terra Firma, for almost 70 years now, and even with my grandmother's old Sorval (SP") gas fridge, I have yet to taste "Odor transferrence". More than likely you are apt to pick up an "Off taste Flavour" from something that has been kept too long in the Fridge, or Freezer. Since some folks with obviously more "esoteric taste buds" than me, have detected differences in food stored in Dual compressor fridges---"More power to them" 2 motors take more power than one , or at the very least run more????. Anyway, the clever Koreans came up with an answer to the folks that had to have "absolutely separated air" between the fridge and freezer. They came up with a single compressor that actually drives 2 separate Evaporators, (dual Evaporators). At least this design is more efficient and less parts to fail. Some claim the Dual compressor and or Dual evaporator fridges keep things longer, and you will see post here in GW that claim same--but-----read on a bit and you will see folks making the same claims about their new single compressor/single evaporator fridges. A typical post, Now all thats nice and good unless you visit the USDA website and look at their recommendations for food storage. So at least (to me), this Dual thing is just "marketing Goobledegoop". A way to get more of your money, without any real benefit to you, and a way to command a higher price. Now more than likely someone will "popup" from the "Tulies" and say, I can't get to store often, so I must have the "Dualie Fridge" in order to keep the food for a longer time, but recall folks make the same claim for single compressor fridges. OK fine, but you better "Pop Your vitamin pills" you ain't getting it from anything inside that fridge, even it it has a thousand compressors and or Evaporators!!! Gary |
- Posted by alwaysfixin (My Page) on Tue, Jun 26, 12 at 23:28
| Dadoes - thank you, that was such a great explanation! Our current fridge has the single evaporator damper system bet. the freezer and fridge, which causes some problems. It looks to me like the more high-end brands like Subzero and Miele would have the dual evaporators. Those are out of our price range. But then Samsung offers more reasonably priced fridges with, in their specs, "Samsung's Twin Cooling Plus System uses two evaporators while keeping the efficiency of a single compressor." Sounds great. How can they do that at a fraction of the cost of the Subzeros? Do their dual evaporators for under $2000 make for a good fridge, or cause problems down the road? |
- Posted by alwaysfixin (My Page) on Tue, Jun 26, 12 at 23:36
| Dodge59 - I didn't see your post before posting mine. We find the issue of single evaporator to be a problem more because of that damper system. Sometimes too much cold dry air goes into the fridge from the freezer side, and sometimes too much warm humid air goes into the freezer from the fridge side. Especially when someone leaves the door open for too long of either the fridge or the freezer, the temps get messed up on the side that was not opened. Yes, we could try to be better about leaving the door open for too long, but reality is what it is. So, I am intrigued by the Samsungs, which are priced fairly reasonably with their dual evaporator/single compressor. Is it too good to be true? |
| There are a few more ways to describe a few more advantages, imho. In addition to the Asian and American names, I can think of some German, Danish and Turkish fridges that have two separate cooling circuits too. Liebherr, Vestfrost, Blomberg, etc. The Summit CP-171 is a Vestfrost under the label. |
| My GE Arctica (approx 8 years old) has a single compressor with dual evaporators. The diverter valve is an additional part of potential failure. The motherboard went bad about 1-1/2 to 2 years ago (which I did that repair myself), but no trouble thus far with the compressor / sealed system. |
- Posted by weedmeister (My Page) on Wed, Jun 27, 12 at 15:00
| I remember watching a video on the GE website explaining their dual evaporator design and its advantages. The thing I remember is a discussion about humidity. That is, the freezer must stay dry since it needs to be frost-free. But dryness is normally a bad thing for vegetables. Separating them allows the fridge side to have a relatively higher humidity which supposedly lets veggies last longer. YMMV. |
- Posted by philwojo (philwojo99@sbcglobal.net) on Wed, Jun 27, 12 at 15:15
| Here is a link to some Liebherr video's. My wife and I are about to start our kitchen remodel and we are going to go with a Libherr for our house. We are going to do two seperate 24" models, freezer/fridge but place them next to one another so they are basically a 48" unit. Hope this helps in your search: |
Here is a link that might be useful: Link for Video's for Liebherr
| Frost-free freezers don't need to stay dry, they're arid by nature. Moisture is continually being pulled from food (which is what causes freezer burn) to condense and freeze on the evaporator, then melts off and drains away during defrost. Moisture is also pulled out of food in the refrigerator section when airflow is shared between the compartments. |
| Millions or billions of "passive freezers" also exist, and work fine. These prove that it is false to think that "the freezer must stay dry since it needs to be frost-free." Passive is a high humidity environment, for refrigeration and fro freezing. Restaurants have this. Very wet. In North America the food packaging industry took over the orientation that fridges and freezers went, after WW2. It was all behind the scenes so you won't find any wikipedia articles about it. Passive freezers are good too. It may happen that you need to defrost once a year, or once every second year, depending on how long you leave the door open in general when you go rummaging for stuff, and depending on the RH of your typical day's ambient air. Dual compressors work for passive refrigeration and freezing too. These are separate issues. |
- Posted by alwaysfixin (My Page) on Wed, Jun 27, 12 at 21:44
| Liebherr's look so great, but out of our price range. Also, we need to stick with the old-fashioned american-style Whirlpool-Amana-ish dimensions of 36" wide and approx. 70-72" tall, due to our existing cabinetry. That's why I am intrigued by the Samsungs with their dual evaporators and pricing of $1400-2000. I may have to post a separate question on this forum about the Samsungs to see if anyone has them. How can Samsung construct a fridge with dual evaporators at that price, while the other brands cost several times that. |
| All the Vestfrost and rebranded Vestfrost are in that price range too. It's not a big deal if the accountants in charge of cost accounting decide to allocate overhead costs differently and deem it to be sufficient to charge X for a small model instead of double that amount. Accounting is a subjective field where they use numbers to track things closely after they finish making their assumptions. |
