Fri, Jun 15, 12 at 1:07
| Hi All,
I have purchased a Wolf 36 inch gas range with a Wolf 42 inch pro hood. What distance do you like from the bottom of the hood to the top of the range? My families height runs between 5'5" to 5'11". Thanks for any suggestions. |
- Posted by mydreamhome (My Page) on Fri, Jun 15, 12 at 7:47
| Both the user manuals will give an appropriate minimum distance. Most often, the distance specced in the range's manual will be a standardized distance reflective of using a basic hood you can pick up at an Lowe's or HD that mounts to the underside of a short set of cabinets above the range (usually ~48"). In your case, it sounds like you are going with a pro style hood, so you will need to go with what is specced in the hood manual (usually ~30-36"). Here's a a good thread on this subject concerning 2 other brands of pro range/cooktop & hood (KA & GE Monogram)... Hope this helps! |
Here is a link that might be useful: Distance Between Range & Hood Thread
