A range hood that isn't a hood
Posted by SeaKoz (My Page) on
Sun, Apr 15, 12 at 0:59
Hi Folks,
I'm hoping I can use your collective wisdom...
I'm looking at this hood: http://www.ajmadison.com/cgi-bin/ajmadison/CC34ISB.html It's a flush mount 44" ceiling fan, I plan on pairing it with a 1500 CFM external motor and will be using it with either a Blue Star 30" or an American Range 30" range.
My question: Is this too good to be true? I'm planning on putting the stove on a peninsula and keeping things as open as possible is a goal for me.
Thanks for your responses!
Here is a link that might be useful: Link to Best Cirrus fan
RE: A range hood that isn't a hood
No way can you run that much CFM through the 6" duct that that thing uses. I doubt it would even do the CFM that it says it does with it's internal blower.
Yes, it's too good to be true. With a high performance range comes the NEED for a high performance hood with some decent capture area. That isn't it.
You'd be much better off relocating the range to a different wall. Cooking is only 10% of the time you spend in the kitchen. Put a prep sink on that peninsula and enjoy the 70% of the time you spend doing that as your social interaction.
Thanks for the response GreenDesigns, I guess I'll keep looking.
They have one of these (a Best - Cirrus) installed at the Purcell-Murray demo kitchen in Brisbane, CA (as of Aug, 2012). It's over a new Thermador Freedom induction cooktop. I was shocked at how well it worked for being so high above the surface. Not too noisy either. Though I think the rep said there was a replacement part it needed that would quiet it down some more.
I think if you get it with an external blower you can size up the duct to 8".
We've looked at them too and wondered how efficient they are. DH thought it was great. I can't figure out why the unit is framed in black metal rather than white - I haven't seen too many kitchens with black ceilings.
Even with a duct large enough for a 1500 cfm external fan, which would preferably be 10-inch diameter, this unit is too small for the height it will be at, even for 7 ft ceilings. Much of the rising effluent would miss immediate capture, and likely would diffuse throughout the house before being cleared by the replacement air. In the meantime, some grease and moisture would collect on the ceilings, walls, and fabrics.
A foot or more of pan overlap would be needed for that height, leading to a hood that might be described as commercial sized. It would, though, not block sight-lines. Of possible interest is that the higher the hood, the more susceptible the rising effluent is to cross drafts and turbulence from people moving about, so the opportunities for escaping immediate capture are more frequent.
kas
RE: A range hood that isn't a hood, continued
I should add that a 3 x 1 or 2 x 2 array of these Cirrus units (depending on ceiling height) might be adequate, so long as the filters are cleaned often. Such a set would be very unobtrusive, and somewhat emulate the commercial perforated ceiling systems, though without their UV systems to break down the grease.
kas
It's not black trim, that's the recessed portion of the vent which just looks dark because it is in shadow. It's all stainless steel.
