| Wolf? Capital? Blue Star? Casual cooking family. More interested in quality than the highest BTUs. What do you recommend? |
| Perceived quality is subjective. There are so many posts comparing these burners, I would read them and then ask any questions you have. Think about how you cook, what you want to clean and what kind of service you want. There are ardent devotees of all the ones you have mentioned. |
- Posted by building_a_house (My Page) on Mon, Mar 4, 13 at 22:53
| Okay. List the pros and coins of each if you don't mind. |
| Quality & Service Capital and Wolf Low Simmer Wolf and Bluestar High Power Capital and Bluestar Even Heat Capital and Bluestar Cleaning Each is different but each requires about the same effort when all types of spills and clean-up are taken into account. Easiest to use Wok Bluestar. Most Effective Wok Capital Bluestar comes with two extra igniters because the igniters are exposed and can break when cleaning. This is not common but it happens often enough that Bluestar has a video on their website on how to change the igniters. Bluestar offers French top in 48" and 60" rangetops. Wolf grill has highest temp but no in between temperatures Capital grill has widest range of temperatures. Griddles are about the same. I think that is more or less the consensus although there are some owner fans of each that will defend the superiority of their rangetop in all things at all times. |
- Posted by SparklingWater (My Page) on Tue, Mar 5, 13 at 7:40
| Nice you're at this stage, building_a_house. Does local or state code limit your ventilation in any way? Our state requires make up air for any vent hood over 400 cfm. For each of those three manufacturers, a minimum of 900 to above is typical. The higher btu burners used for wok cooking produce a plume whose swift capture may be added by higher cfm draw. There are make up air universal damper systems which senses within the hood duct and runs with turn on providing non conditioned fresh air. Broan was the first in supplying them for residential use (no affiliation, just gratitude). An 8" duct is typically used on these systems for 1000 cfm blower capacity. Over 1000 cfm, two 8" mua ducts to outside may be needed. Something to think about in this equation. O/T: how tall are your ceilings? Are your upper cabinets 42" then stacked? The glass at top is wonderful, and I'm sure you have thought of the need for a library ladder. I love the design of your kitchen. |
- Posted by building_a_house (My Page) on Tue, Mar 5, 13 at 8:20
| @SparklingWater: No make up air code in my area. I am going with a 600CFM Moderaire insert. Yes, I know that they recommend that I need more but honestly it will be very rare that we use more than 3 burners. I have posted on this before and have received excellent feedback that for me 600CFM will work very well. The Modernaire has an 8" duct that I am able to run straight up, into the attic, and out the roof above. The kitchen ceilings are 10'. I am not sure about the heights of the uppers. Yes, the top cabinets will be for storage of items that are not used very much. We will have under cabinet and upper cabinet LED lighting. |
| My take with numbers, from the manufacturers BS CC Wolf I would see each in person and try to cook on them to see how they are. You can see how you like the way the heat adjusts, fit and finish and just how it feels to stand in front of it. If I were wanting a griddle, consider an add on, either the steel Chef King for 2 or 4 burners(heavy and holds a lot of heat) or the aluminum(responds quicker to changed in temperature and is lighter weight) uncoated Royal industries over 2 burners. " Posted by deeageaux Even Heat Capital and Blue Star " The burner that has the most even or useful heat for one pan will not be the best for others. No one burner can be all things. It is helpful to consider how heat makes it to your food. One aspect is heat transfer from the flame to the pan. Each of these burners has a little different pattern. Sealed burners can have more flare on highest heat. This might be good or bad. There is very little difference on low or medium heat. If you use a pan with adequate aluminum or copper that conducts heat well, it is less significant. If you use cast iron or steel, you will want to consider how the pan heats in order to choose a burner that works well for you. You might like the smaller footprint on high heat of an open burner for a wok but a twelve inch skillet will heat better with the sealed burner with some flare. The burner is only one of the variables in bringing heat to your food. The pan luckily is an easily changed variable and by understanding the properties of the pan you will be able ti adjust o any shortcomings of your burner. |
Here is a link that might be useful: Material used for cookware
- Posted by building_a_house (My Page) on Tue, Mar 5, 13 at 17:34
| Great posts thus far. Does anyone else find the aesthetics of the blue star a little lacking? |
| To me, your question is like asking Mercedes, BMW, or Audi? Ask the owner of any, and more than likely they will tout the one they own. You are looking at the best of the best, there is really no wrong decision here. And, as for the aesthetics of Bluestar? It's all In the eye of the beholder... I think mine is drop dead gorgeous :) |
- Posted by buffalotina (My Page) on Tue, Mar 5, 13 at 22:41
| Is that picture the plan for your kitchen cabinets? It looks like that layout calls for a cooktop, not a rangetop. |
- Posted by building_a_house (My Page) on Tue, Mar 5, 13 at 22:55
| The cabinet designer did not have a rangetop in his software. Yes, it will be a rangetop and not a cooktop. One of the reasons that I need to decide is to give he and the granite fabricator the exact cutout measurements of whatever I want to use. |
- Posted by breezygirl (My Page) on Wed, Mar 6, 13 at 0:56
| I enjoy my CC 36" 6 burner rangetop, but do not want to get into the old "flame wars" of threads past. After getting my simmer adjusted properly, I can simmer very well on a couple of burners and decently in the remainder. On the opposite end, I like that any of my 6 burners can crank to a raging inferno. Cooking is always extremely even across each burner. I don't really find cleaning difficult. As far as the granite and rangetop, each fabricator with whom I spoke wanted the rangetop on site for templating. Simply having the dimensions was not enough. You might want to double check with your fabricator. |
