Range hood recommendation
twitter007 (
Thu, Mar 29, 12 at 17:34
| I currently have a cooktop with downdraft and it's horrible. Planning to add an undercabinet range hood and looking for some recommendations. I don't have a fixed budget but hoping to find something nice for around $1000. It needs to be at least 600 CFM and have to the capability to be vented from back.
I think vent-a-hood fits nicely in my price range but found mixed reviews on it. Some folks think it's too hard to clean and technology behind it is over-rated.
Also, appreciate some pointers on places to buy in San Francisco Bay area. |
RE: Range hood recommendation
| I am curious of what everyone recommends also. We are getting ready to break ground for our home-- looking at either a range top or a range. Hoping The Blue Star RCS is something we can get. Read that Modernaire is good choice--but I have no clue how much? |
| New here and in the same situation. I'm looking for 1000 cfm (not 1400 cfms, which a lot of Pro line seem to sell in blowers/fans and which would definitely highly impact make up air need, not that 1000 cfm is small, its just what we currently have and we've been fine). At 600 cfms, you should have a wide selection of rear backing vent hoods. As already mentioned, a good way to search for your needs is through ajmadison.com (not connencted) or other online appliance co., as you can check box your desires (like cfms, wall vent, width, price range etc) and then proceed to read the specs to see if it back vents. From what I see, Modernaire is a semi and custom line, pricey and beautiful. Doubt anything less than $2k, but could be off. Hope this helps. Good luck. |
| Many people are happy with Kobe hoods. I can't speak from personal experience but that's what I'd be looking at if I needed a new hood. Get one with baffles not oil catchers. |
| I am also looking for a 600 or so cfm range hood to go over a new DCS, so thanks for starting this thread. Just wondering what are baffles vs. oil catchers. Also, are slides outs okay in general? |
| Although I have a Wolf hood made by Independent, many here operating in the higher flow rate regions have had good results from ModernAire. Reportedly they will build to order so odd-ball size requirements are not a problem. A search of the forum will turn up additional information. kas |
I have a Viking with heat lamp. I'd give a lot of thought to the idea of putting a 42" hood over a 36" range. While that may have some popularity in this forum it's a fairly unusual configuration and one you likely may not need with a range unless you are mounting a hood higher than normal. Cabinet placement could impact that as well. Before you select an appropriate CFM consider having a qualified installer come look at your home. The length of your exhaust run, the diameter of the venting and how many turns in the exhaust can have a dramatic impact on the CFM you need. Every 90 degree turn in your exhaust venting results in a substantial loss of CFM. If you want quiet get the external blower. FWIW my Viking hood is now 12 years old and never a single problem. (knocks on wood) Width is not nearly as important as depth (IMO) in your hood. Unfortunately you may have to go wider than your range to get a deeper hood. Enjoy the new kitchen! |
Thanks to everyone for their input. I'm trying to figure out what will look best in my kitchen, a under-cabinet hood or a wall-mount hood. http://www.flickr.com/photos/11255303@N02/7033136853/ Distance between cooktop and bottom of dish rack above is only 27 inches. Even if I find a 9" high low -profile hood, I'll still need to modify the cabinet by removing either the dish rack or the decorative piece on top it. If I go with a wall-mount, then I can just remove the cabinet altogether but not sure if look good. |
Here is a link that might be useful: Kichen pic
| You might consider having a hood insert built that fit inside a wood structure that integrated with and continued the present style of cabinetry. kas |
| Thanks Kas. That's exactly what my wife wants. These are KraftMaid cabinets which were most likely ordered through Home Depot. I should probably go talk to them to see if I can order a hood insert. Also, I searched but didn't find any hood inserts which vented in the back. Does anybody know of one? |
| I would ask Home Depot for an insert with SS baffles filters as opposed to mesh filters much better long term. |
| I watched a Pro Line video installation recently and perhaps this is worth considering for you. I want an exterior fan/blower system. This is in-line. ProLine's corporate office is in Salt Lake City. The smallest undercabinet is 30" yet both offer the low profile you seek. |
Here is a link that might be useful: Under Cabinet Pro-line 36
| Trevor (the CC guy at euro-stoves) has the exclusive contract on Modern Aire on the web - so you could call him for prices. I think modern air 42 inch is in the $3,000 range. I have been told you need 42 inch hood over a 36 inch range if you are putting it in an island or are installing a grill. But, you should fact check this with an expert. I have heard Farber is good and more reasonably priced, but don't have any experience with it. |
| More precisely, the hood size has to encompass the rising and expanding effluent from the pots and pans (not the stove top area). The effluent may be simply thought of as expanding at a 45-degree total angle (22.5-degree half angle) from every point on the hot pan surfaces. (For gas burners, include a little more diameter for the combustion products passing around the pot or pan.) The higher the hood the larger the aperture should be. A simple diagram drawn by straight edge and protractor from a front view and side view will reveal the desirable size in lieu of calculating it using trigonometry. At high flow rates, the effective aperture may be _slightly_ larger due to air flow around the hood edge. Also, a wall behind the cooking surface and cabinets at the sides will somewhat duct the rising effluent and allow a reduction in the size of the aperture. kas |
| Futuro Futuro makes inserts that can be vented back. |
Here is a link that might be useful: insert
| We really like our Kobe wall-mount chimney hood, which checks all your boxes (or at least it did when we bought it a year ago...) They make a number of versions of it, though I'm not sure if inserts are among them. For places to buy it, depending on where in the Bay Area you are, we've been happy with Galvin Appliance in Albany over the years. Airport also carries a wide range of hoods, but I've never been able to nail down a good salesperson there to answer questions (supposedly there are some, so that may just have been bad luck on my part...) |
| I have the Zephyr 2100 hood (from Galvin Appliance) which I think fills all your specs. I wrote a full review on it last year, here's the link. |
Here is a link that might be useful: Zephyr AK2100 rangehood
| We bought the Kobe CH2230SQB after much research. It is a 720CFM 30" undercabinet hood, can vent out the back, has baffle filters. They make a 36" too. I'd love to tell you how we like it, but it was just shipped to us and we're still awaiting installation. Based on all the research and reviews we looked at, we expect to love it. We ordered through AJMadison but kept getting told 'another two weeks until it ships' and eventually canceled our order with them. I called Kobe for advice on who to buy from and they directed me to www.thenaturalhome.com , who were super-great to work with. It shipped out the next day. |
Here is a link that might be useful: Kobe CH2230SQB
also...
| Meant to mention that the Kobe is in the $700's, so within your price range. |
