Fri, Mar 23, 12 at 14:24
| We are considering installing a Miele plumber in coffee maker. Our water system is well water, however, we have a reverse osmosis filtration system for drinking water. Has anyone had any issues with using this type of water in their machine? |
- Posted by weedmeister (My Page) on Fri, Mar 23, 12 at 16:11
| I would think RO would be fine if you can generate enough to fill the tank. |
| Much of the municipal water supply in the US is well water. You should have no problem with your unit provided you find the osmotic system puts out a palatable glass of drinking water. If you intend to tap off the RO system, then use that water for your initial hardness test. (The machine is sent with a water test strip. You follow the instructions to get a numerical value of the hardness of the water and enter that into the coffee system's NVRAM as instructed) The hardness test tells the machine how often to call for a descaling procedure. |
- Posted by fourkids4us (My Page) on Fri, Mar 23, 12 at 19:30
| My neighbors have the Miele built-in coffee system. We are on well water and have RO. She loves it! She did have techs out once for a repair issue, but I've never heard her complain and they've had it for at least 5 years. |
