| We have finally decided to switch from electric to gas. I want all four burners to have the same btu's. We are on a budget - definitely under $2k, preferably around $1K.
The ranges I like best are all freestanding. I know we can cut the countertop at the back, but I am worried about the sides. The current range top overlaps the counters on each side. Will I have a gap with the freestanding? Will it be at the same height? Thanks for your help. |
| The only way to know for sure is to measure the opening, and measure potential ranges. I replaced a slide-in with a free standing in my previous home with no problems (aside from removing that back piece of counter). The opening was just a bit larger than 30", so the side gaps were negligible. |
| It should be the same size, but not all slide-ins are the same. If the slide-in was made in the 1950s-late 1970s, you might find some unusual dimensions. The more recent ranges are usually standard sizes. |
- Posted by oasisowner (My Page) on Sat, Mar 3, 12 at 11:40
| Thanks, ours is a 30" newer Jenn-air, so I guess we should be OK. We found a good deal on a Kenmore Elite 5 burner gas range, but I am disenchanted with all Sears products right now (after problems with two washers). |
| I replaced a slide in with a free standing last month. To do so, I had to have someone cut the granite on both sides of the stove. I was very apprehensive, especially since a bunch of granite fabricators wouldn't take the job worried that the granite would crack. We found a great guy from Angie's list who did a very nice job, contained the mess and there were no damages. The gap is hardly noticeable. |
