Breaks in enamel finish of (relatively) new Wolf oven?
We have 30" Wolf wall ovens that have been in 2.5 years. They don't get especially heavy use (light to normal I would say -- many days they are never turned on at all because we grill or use the gas rangetop), and we've only had to run the self-clean perhaps a half dozen times since we've had them. We noticed recently that on the floor of the upper oven, that beautiful bright blue enamel had what for the world looked like scrape marks (except that NO ONE has scraped it with anything at all, much less something seriously metallic which is what it would take to dig into the enamel) toward the left rear. Sort of a small clump of lines where the enamel is clearly broken. Just ran the self-clean on that oven last night, and found a new area, looking identical, of "scrapes" at the front center. The enamel actually came off in bits when we wiped down the oven with a damp paper towel post-cleaning. These areas do not correspond in any way to the "feet" of the pizza stone element, which we have used occasionally. They seem to be completely random in location.
So my question is whether anyone else has had problems with the interior finish of their Wolf ovens. We have called Wolf and they are looking into it. The ovens are obviously JUST out of warranty by a few months, so incredibly annoying and we hope they will (a) have an answer as to what might have caused this and (b) stand behind their product. This is on top of already having replaced the complete electronic control panel for these ovens once. To say we are unimpressed with the quality of these ovens so far, especially for the price!, is an understatement.
Comments (55)
pugger
16 years agoE Series are less expensive? They appear the same on the inside & tout the same functions as what I have. But I'm surprised they're less expensive. I'll have to price one out.
ctlady_gw
Original Author16 years agoWe checked out the E Series on their website -- looked as if the lower oven has only 4 cooking modes and no convection? Also no rotating control panel (though that would be FINE with me). The features do seem more streamlined. We were told we would be getting the "-3" model (better than the "-2" model of the L Series we bought in 2005. Have no idea what the differences are but we were told it was somehow improved.
chipshot
16 years agoI don't recall the specifics of the E-series, but it seemed like significantly less functionality for not a lot less money. And while I like the sleek look of the E-series, DW is smitten with the rotating control panel on the L-Series (hmmm, I wonder where Wolf came up with "E" and "L").
Our ovens haven't been delivered yet. When the are, how will I be able to determine whether they're "-2" or "-3" models? How about determining the same for Wolf ovens I see installed elsewhere?
ctlady_gw
Original Author16 years agoE-Series seem definitely lighter on features: no convection for lower oven, 4 cooking modes instead of 10 in lower (I presume because no convection), fixed control panel, etc.
The "-2" or "-3" (there was a "-1" I at some point, I assume) is on the rating panel (bottom of the control panel -- you have to crane your neck but it's there), along with the serial and model numbers.
We have the rotating panel on our L Series and virtually never close it. I don't like it particularly because it never feels securely "locked in" place (may just be ours I suppose) -- it yields a tad when you press the touch pad. I've actually occasionally felt I had to use my other hand to hold it in place (I'm told I'm probably pressing too hard on the buttons, but it does give a bit no matter how lightly I tread on that touchpad). We closed it a lot the first week -- virtually never since then.
Have no idea, by the way, what the "-3" gets us, just that it's the latest and greatest model. I just hope they've improved the enamel.
You all should be aware, if you have new Wolf ovens on order, that you may get a very loud "crack" sound the first few times you turn them on. Sounds like a gunshot, or an auto backfire. Doesn't always happen, I guess, but it is apparently very common -- so common the Wolf receptionist who first answered my call was able to tell me exactly what it was and what to do (you'd think they could save some calls by mentioning it in the manual?) We called in an absolute panic when it first happened and were told it was perfectly normal: it's the oven floor expanding (huh...?) The fix, according to Wolf, is to run the self-clean cycle several times when you first get the ovens. But the noise is alarming in the extreme if you don't what it is!
pugger
16 years agoYea, we had the "oil canning" with ours. Running the self clean a couple of times cleared that up. Makes me wonder if the noise was also the paint chipping/cracking as it seemed pretty violent at the time.
I'm disappointed in the E series, but they do need to become more competitive w/ prices and quality. Maybe this was their attempt on the built-ins.
lascatx
16 years agoI didn't have that problems, but I had a bad heating element, a rattling fan and a fogging control panel -- then started smelling something electrical overheating. Wolf agreed to replace the ovens without having anyone even come out to verify the problem (which could have started a fire -- so I guess that was smart). I called them last Monday and got my new ovens today.
I'm running a pre-cooking cyle after cleaning the ovens, and I can already tell that this one is put together better. The racks glide easier and quieter. The control panel is more responsive than the last one (although the original one was good, but fogged. The replacement wasn't fogged, but was harder to get to respond). They are quieter. In short -- they seems to be more of what I had hoped for whan I bought the Wolf. I'lll get to bake with them tomorrow and hope I am as happy then.
Ctlady, I hope you we will btoh be as pleased ater using the new ovens. Good luck!
lascatx
16 years agoI also menat to say that we haven't heard a single popping noise. This has been worth the inconvenience of getting a replacement.
BTW, mine were just over a year old.
jerrylee12
12 years agoWithin the first 6 months of owning our double oven we two problems. The first was a LOUD pop in the metal almost every time we turned the oven on. No one told us to run the self-clean cycle (as mentioned above) but we called the dealer who came out and installed a reinforcement piece from the rear which fixed the problem.
A month or two later we had a non-resettable fuse blow out after a self clean. The dealer came out again, pulled the oven out, and replaced the fuse with a new and improved self-resetting fuse. Both of these problems made me wonder if I had picked the wrong product.
It's 4 years later and my latest problem is the finish on the floor of the upper oven which has several cracks and chips. At the advise of my dealer I paid them to come out and take photos. They agreed that it was a defect in the finish so they sent Wolf the photos and their report. A few days later I was called by my dealer who told me that Wolf wanted me to call them direct. Wolf told me that they don't make the part I need because they never have this problem (right) and the enamel finish is considered an appearance item and therefore not covered by warranty (which I think is total crap). They did give me two choices.
The first choice is $500 and an extra year of warranty. I consider this a bad choice because in my opinion after another few hundred cycles I assume that the finish deterioration will accelerate and I'll be left with an ugly mess. Option 2 is a new oven for $1900 plus delivery, tax, and installation. I consider this another bad option since for around $2500 I will end up with the exact same oven that I purchased 4 years ago thinking I was good for maybe the next twenty years or so. In my opinion, it's not out of the question that the faulty finish began to fail because of the five or ten times the floor popped when the oven was new.
I noticed in one of the postings above that Wolf offered a new oven for $200 for every year it was out of warranty. That at least seems like a decent offer and I will hope for the same treatment as I continue to talk with Wolf.
Thanks for all the postings. This will surely help me as I go through this problem with Wolf.
jerrylee12
12 years agoWell, Wolf stepped up to the plate today. After I forwarded my thoughts to them they said they would sell me a new oven for $500 plus tax. Corporate had to call the distributor to get a price for delivery and installation. The distributor told them $600. I called my dealer/certified installer and asked how much to swap the units. I was told it would take approximately 1 1/2 hours @$80/hr plus parts. If I round that off high at $200, that leaves $400 for delivery...kinda steep for an hour drive. I will hope for a better offer tomorrow.
I am pleased with this offer from Wolf corporate. I would not have been pleased to pay the $1900 plus extras. I only hope they have gotten rid of the loud POP on the newer ovens.
seb7777
12 years agoIt's mid 2011.... I have a new wolf
Model
DF486C - 6 Burners, Charbroiler $12,885*Hardly used 6 months old , I ran the self clean cycle and noticed scraped cracks in the far back corner of the smaller oven ,
Called wold and ran the larger oven and it splinteredWolf replaced an entire new range at no charge in 12-2011
It's now 3-2012 and I have the same cracks in the back of the small oven
Without running the cleaning cycleThis 2nd oven oil cans something awful pops when you turn on and off
I never ran the self clean cycle yet only the burn off cycle they suggestI am in talks with wolf now, I can't believe 12'000 gets you dual lemons not dual ovens
I had a ge electric wall oven for 15 years and never one service call and a whiz to clean
hdhanna
12 years agoThis just happened to me too! I'm devastated. I have 2 wolf ovens, and the one that gets very little use has cracked after I self-cleaned it last night. I just sent pictures to Wolf and am waiting to hear what they will do. I'm 2 months out of my 2 year warranty - UGH!
My Subzero Frig needed repairs within months of getting installed, and my Wolf induction cooktop was finally replaced with a Miele when THREE DIFFERENT cooktops all had the same issue. This company may be going downhill. I will keep you posted as to what they will offer me.
hdhanna
12 years agoUM - crazy update. Today a guy told me it is just "Cosmetic" and not to worry about it. Let them know if the oven is 'off' a little, but it should be fine. IT'S NOT FINE!! I'm probably going to pursue getting new ones. I don't think you should pay 4 grand for an oven that can't stand its own heat
ctlady_gw
Original Author11 years agoI am on my second set of Wolf Wall ovens (I was the OP on this thread)... we now have the same "scraping" (crazing, chipping) in the enamel on the floor of the replacement ovens. The trouble areas are in exactly the same spots on both upper and lower ovens (aligning, I assume, with some portion of the heating elements). Left and right sides, halfway back, 4 inches in from the walls, and an area dead center, 3-4 inches back from the front edge. Striations of crazing out from those, like mini waves. I am going to call Wolf but am not optimistic of any real assistance. I am just stunned at quality (of lack thereof) of these ovens. The "high-limit" switch trips (and requires a service call to reset, at $180 a call) on occasion PURELY as a result of running the self-clean cycle... and now the bottom of the oven is once again defective. I had GE wall ovens (nothing special in terms of upgrades, etc.) for TWENTY YEARS with no problems! I have a call into Wolf and will see what they say... but I do not, unfortunately, expect them to do more than offer to SELL me a new set of ovens... nice blue interior. Good for another 4 years ... if I'm lucky and ... don't run the self-clean cycle EVER.
ikeltz
11 years agoThis all sounds pretty scary. We were considering a 36 inch all gas Wolf stove, but now I'm not so sure. So glad I found this thread.
jellytoast
11 years agoDon't be scared off, ikeltz. These complaints all have to do with electrical issues and running the self-clean cycle, things that you won't need to be concerned about with an all gas range. And at least Wolf offered some sort of resolution.
dodge59
11 years agoSee the posts, "Problems with Wolf Single Oven E series",
(Just do a search at the bottom of the main appliance page) for Wolf Ovens.One would suspect that Wolf is using the same porcelain in both the AG ranges as well as the Electric Ovens----Something that I would certain find out about (Note I said "suspect") so best to find our yourself before any purchase decisions.
It is correct that
"Wolf has at least offered some sort of resolution"
but what it the oven fails after 3 years or so, do we now expect to be replacing expensive ovens and ranges in less than 5 years now???, I sure don't and my current oven is going on 7 years now, trouble free. Should the porcelain ever be damaged at the oven bottom, the whole bottom just lifts out and could be easily replaced,
(alto as I mentioned No problems thus far).One should spend some time "Googling" other sites, Echow, Fix it, Epinions etc to get some idea of how widespread this porcelain problem is, Google wolf oven problems, or Wolf oven porcelain or something of the sort.
Good luck with our decisions!
Gary
jellytoast
11 years agoDodge59, I was only saying that the porcelain being damaged might have something to do with the high heat of a self-clean cycle, something that the all gas range doesn't have. The all gas range also doesn't have the same blue porcelain. And, like your range, the bottom panel in the oven is a separate piece.
This post was edited by jellytoast on Sun, Feb 24, 13 at 10:33
kalapointer
11 years agoI have a Wolf E series with chipping porcelain. But I don't think it is just the heat of self cleaning that causes it. Otherwise the chipping would be at random places in the oven. It maybe a poor design of the liner and the chipping is at stress points (where the bottom meets the side walls) and that when it heats up the bottom expands and pops causing the crazing and chipping. Wolf is replacing the oven and I was told that the interior has been redesigned. We shall see when it is replaced next month.
April
10 years agoWe are in the market for a Wolf DF range. Obviously these posts are worrisome. Has anyone experienced the cracking in Wolf ranges?
wekick
10 years agoYes and I have posted a lot about it. Not 5 years old and I am looking to replace it. Right now the oven is extra storage until I figure out what to do. You can't really use it because there are shards of glass coming off and add to that a convection fan blowing them around. I wish that I would have bought the oven and rangetop separately. I have an additional wall oven so I can get by for awhile. I am thinking about putting in a rangetop and another oven somewhere. It might involve tearing out and rebuilding cabinets though. The people who fix Wolf have had experience with this issue and I live in a smaller market.
redoingit
10 years agoaprilh, our 36" DF purchased in 2006 does not have a shard issue. We have used the pizza stone and cleaning features. Perhaps we dodged a bullet. That said, I agree with every poster's opinion that such a "defect" is not cosmetic, and warrants replacement, even at 6 years. My suggestion is to make sure you use the cleaning feature early-on so you can take advantage of the warranty if it happens.
wekick
10 years agoI used the cleaning feature early and it did not show up during the warranty period. I have a wall oven that I use the most so the Wolf oven does not get used heavily.
Yvette Sprague
7 years agoWe have had the same scoring problem with the floor of our Wolf oven. Ours was 2 years old when we noticed it. We replaced the oven floor with a new one around Thanksgiving of 2015. Now in July of 2016, the new one is starting to show the same signs of scoring. I surmise that it may be due to a problem with the process / procedure that is being used to apply the surface coating to the oven floor. What is really strange is that the scoring patterns are identical on both the original and the replaced oven floor.
hansonjoan1234
6 years agoI am now on my second Wolf Range the first range was purchased in 2006. The first time I cleaned the oven the enamel cracked, Wolf replace it but they had to take whole range to the appliance store for the repair it took seven men to pick it up and take it out I have cherry floors, I had no stove for over two weeks. I continued to have problems with thinks thinks on the range so Wolf brought in a new range, now my oven is cracking again.
I really like my range I wish Wolf could come up with a solution for this problem. I must say the customer service has been very helpful.
b17nav
6 years agoSame thing happened to me. Luckily it was within the warranty. I have had the replacement for 9 months and the exact same thing is happening. I will have to give them a call, but this is very annoying. For the price you pay these imperfections should not be happening. I have the E Series double wall unit.
Jackie Lin
6 years agoI am just about to purchase their steam convection oven + E series single oven + 48" rangetop, I emailed the customer service about the blue enamel problem and this is what I received. (See below). Should I go ahead with my purchase? After all it's not a few hundred dollars purchase and I don't want to regret making the purchase.....
Good morning,
Wolf Appliance has taken extraordinary measures to repair or replace every homeowner’s oven in the relatively small number of instances where porcelain issues have come to our attention.
Wolf continues to focus on producing cooking products with unparalleled quality and impeccable craftsmanship. Our ability to offer one of the strongest warranties in the appliance industry speaks to our confidence in our manufacturing, testing and quality control processes and our commitment to customer care.
If you have any further questions, please contact us at 800-222-7820 or by responding to this email.
Regards,
Customer Care Email Team
800-222-7820
wekick
6 years agoAnd my DF range still sits all chipped up.
You can search on this forum for what happened to me. My greatest regret in my kitchen.
ctlady_gw
Original Author6 years agoInteresting... was not aware of the lawsuit. Our (third set) of wall ovens have so far been okay, but having to replace the units twice is unacceptable even IF the third time is the charm. What I will say is that the service guys who came out the second time, to replace the SECOND unit, volunteered that they had done "about 30 of these this month" for the same problem. I got the same response from Wolf when I called as other posters: they said it was a "very rare" problem affecting a very small number of customers. The comment by the service guys (not Wolf employees) would seem to put the lie to that. I believe it was and perhaps still is a widespread manufacturing problem. They told us after the first failure that the company had changed the enamel source and formula (even though it was a "very rare" problem! :) ... I just know I will never buy a Wolf product again.
Jackie Lin
6 years agoSo I ended up not getting the wolf wall oven because Of the blue enamel issue. Got Miele steam convection oven and wall oven instead. But I still got the Wolf 48” rangetop. Happy with the combination.ILoveRed
6 years agoJackie..I just ordered the Wolf 36" rangetop, m wall oven, and steam oven.
i can see where you are coming from. I can't get service from Miele in my area or I would have considered this as well. I can get service from sz/wolf. Hope I don't regret this decision.
Michelle Sharpe
6 years agoI actually had a wolf rep acknowledge the problem. He said the element in the older versions of the ovens was too close to the floor of the oven causing the enamel to crack. Proximity not temperature was my understanding. We’ve had this enamel issue with other lower end ranges as well.Marcus Moreno
3 years agolast modified: 3 years agoIt is the frequent self cleaning that is causing this (cracks, overheatin). Especially baking soon after a self clean cycle. Clean up mess right after use and do not use self clean more than needed.
wekick
3 years agoMarcus Moreno, What is too frequent to self clean?
Some people have never used “self clean” and still had chipping.
” Especially baking soon after a self clean cycle.”
What is too soon? What is the explanation for why this would happen?
Wolf promotes the “self clean” feature as a benefit. It looks like they are throwing in the towel and admitting chipping will happen.
This is from the M convection oven manual.
They are trying to say it is cosmetic.ctlady_gw
Original Author3 years agoWe got the run-around from Wolf when we encountered this YEARS ago (no idea it was still going on... thought they had changed their design and their enamel vendor??) We went through two brand-new wall oven sets. The third has been okay and has been in for years now, but the first one chipped after -- literally -- two self-cleaning cycles that were months apart. The second lasted a bit longer -- maybe 2 years -- before it did exactly the same thing in exactly the same area. We not only didn't run self-clean very often, we didn't even use the ovens that often. It was the service guys who replaced these units (no easy task as built in wall oven sets) who said they were replacing them at a rate of "dozens" a month. So yes, this was a manufacturing/design problem (with the heating element for the lower oven too close to the floor of the upper oven) combined -- Wolf conceded to us -- with an enamel product not up to the heat. Their customer service indicated that was why they were changing the enamel vendor. It was Wolf's problem and they knew it.
hvtech42
3 years agolast modified: 3 years agoCurious @ctlady_gw, how often have you used this most recent oven that hasn't had chipping? Any change in usage patterns from the previous ovens that did chip? Frequency of self cleaning?
By the way, I highly recommend that anyone looking to buy a Wolf wall oven buy the M series instead of the E series. As has been discussed on here many times previously, it has a removable bottom, but I had a look through the parts catalog and service manual, and it turns out the oven floor is quite reasonably priced for a high end appliance - $100 - and it looks very easy to replace, even as a DIY project. So if it chips out of warranty, even if Wolf refuses to help out at all with parts and labor, you can fix it cheaply. The other cool part is that you can replace the hidden bake element without pulling the oven from the wall, which is not the case with most ovens.
ctlady_gw
Original Author3 years agoNo real changes in our oven use... except maybe we don't look too closely at the floor of the upper oven these days! ;) We never used the self-clean often and still don't... but not NEVER. Just not often. maybe a few times a year.
wekick
3 years ago@hvtech42
The M is easier to repair but if you plan to fill it side to side as they advertise, the sides tend to overbrown because the fans blow directly down the sides. There have been several complaints here about that. It also does not have convection bake mode which is the most usable to me.
Compass Real Estate - Suzy Armstrong
3 years agolast modified: 3 years agoMine came with a huge roto-saw gash in the bottom. It is so deep that you can see down to the steel. I didn't even notice it because when installing it, they conveniently placed the roasting pan on the lowest shelf in the top oven where the damage was. Baffling what/who could have caused this???
wekick
3 years agoI don’t know what caused it. It could have been anything. Call Wolf immediately and ask for a replacement, not just a replacement of the liner. No telling what other damage is done. I would Let the owner of the business know about what his employee did. Did it come in the original packing? I once bought a wall oven that came looking like it had rolled around in the back of the truck for 500 miles. The dealer knew what he was sending because when he called, he said we already took it out of the box to check it. And missing all the booklets, probes and the inside being all chipped up was acceptable?
mid the dealer doesn’t respond appropriately by immediately saying they will replace it, ask Wolf to have another dealer do it.
meghang93
3 years agoWe had the same "roto-saw gash" appear after just a few months of use. Wolf calls this crazing of the oven cavity. We are our currently on on third replacement oven cavity and the crazing continues to reoccur.
HU-727293984
3 years agoI have had this problem of chipping and shiny dandruff like flakes in several new ovens that I returned. I even got an Italian stove and had the same problem in Canada. Who supplies the main parts is what I’d like to know. Four years ago when I lived in Europe I bought a medium priced oven and didn’t have this problem.
Lisa Wilson
2 years agoI am having the same problem with a year old Whirlpool wall oven, tiny glassine flakes are coming down from the top of the oven, I wonder if the broiler element is too close to the enamel as I've never used the self clean option on this oven. No help from Whirlpool, the technician insisted it was "grease". I am very unnerved to think these flakes are going to be landing in our food. Very, very frustrating. Anyone else have this problem with a Whirlpool oven? The technician insisted the only issue like that was with Kitchenaid blue interior ovens. I beg to differ.
RCI Construction
2 years agoI have this pr on my wolf 36” gas oven It started after the first year and I thought it was just food at first but my whole oven bottom is all big pits of ename gone I just wiped it with a damp cloth and the enamel is chipping and coming off terribly
Liz Engel
last yearI bought a Wolf Range and immediately started having enamel issues on the range top and inside the ovens themselves. The first replacement was inside the warranty window in 2018. However, the registered repairmen also bent the hinges when replacing the cavity which was obviously my fault at $400. Recently I cooked a Tennessee Peach Pudding and it spilled over. When I wiped it out, the enamel came along with it. Deep crevices of glass have come away. The registered repair company, Bekins just left and quoted me $3400 to replace the cavity and I could take it up with Wolf if I wanted to complain. Also, 2 of the nobs are springing back to low on their own and not staying in possession. This replacement per Wolf requires that all valves be replaced. I don’t think I’ve ever spent so much money on such an inferior product in all my 60 years. I’m awaiting the call back from my complaint made today.
cgartke
last yearWe got our Wolf 36” range last summer (2021). About a month later after self-cleaning we noticed a deep scratch in the bottom. We had the oven liner replaced. Second liner soon had the same issues happening on both bottom corners, even before self-cleaning. Now waiting for this one to be replaced but have questions about what is really going on here.
Liz Engel
last yearAgree! I was able to get parts and half the labor covered. There’s no way this is acceptable. I called Wolf and they acted like it was an isolated incident and it’s is not. There was a class action law suit. After that call the repair people. Then get ready for a fight if you have to but I was able to get half the labor as I said.
Hilary Scholz
last yearThanks every for your input. We got our double oven 13 years ago and I had noticed some crazing. Unfortunately I didn’t think much of it. Now the area has been fully exposed and looks like a bomb explosion. Had I realized there was a issue with the enamel I would have reached out to Wolf right away. To this day we still have a popping sound when our oven cools down too.
Yolanda
3 months agolast modified: 3 months agoToday I came across a lot of comments on Wolf's social media pages of people complaining that their brand new ovens have sharp shards of blue all over the place - and in their food! It truly baffles me that this luxury company won't just take that darn blue enamel out and replace it with something else.
It's been over a decade of this issue and many lawsuits!!!
I'm having some thoughts about just using a combi steam oven and a speed oven as my 2 oven set up - as both of these wolf products have stainless steel interior and no enamel to worry about. Does anybody have anything thoughts about this setup? Would I even miss having the regular convection oven with a speed oven + combi steam oven?
pugger
