I have only 33' for a frig~~
Posted by phoggie (My Page) on
Sun, Feb 19, 12 at 19:20
I am considering buying a small condo and there is only a 33" space for a frig. I am so spoiled that I like my water/ice in the door. Is there any make of frig that is this small with the outlets in the door? Thanks!
RE: I have only 33' for a frig~~
Go to AJMadison.com
Hover over "refrigerators" on the menu bar then click on "Full Size Refrigerators".
Then in the "Refine your results" on the left hand side, go down until you see the "Width" section, and type 33 in both the From and To boxes then click on the little arrow next to it. Change the From to something smaller than 33 if it makes sense for you to look at smaller fridges too.
Now, to finish, you want to only look at fridges with water/ice in the door. On that same "Refine your results" area, find the "Features" section and click on "Water Dispenser - External".
You should now have a list of several hundred fridges to choose from. Add additional filters if there are other features you can use to narrow down your choice.
