30" Capital Culinarian Manual MCOR304?
Posted by blackie68 (My Page) on
Tue, Feb 18, 14 at 16:25
Does anyone know what the new changes are on the 30" Capital Culinarian Manual. (New model # MCOR304N). I heard they change/ replace the center cast iron grate to a stainless steel plate or something like that? Can't find a picture on capital web site showing new model, any one have a picture of it or info?
Thanks in advance.
RE: 30" Capital Culinarian Manual MCOR304?
Go to the listed link, and click on info & guides. It will bring up the pdf for info on this model. Hope that helps.
Here is a link that might be useful: info form model
@ rayjuncajun, the link Is showing Capital Precision Series MCR304N which is sealed burner. Did capital do away with the open burner on the 30" manual clean Culinarian?
Looks like the back trim is gone too.
I am new this this forum. Not sure if I am doing this right.
posting a picture of the MCOR304N - Culinarian manual clean.
Alex from Absolute Appliances in Los Angeles sent me this picture last week.
Chris thanks for the picture. I see they did few changes to the model. I wonder how high the center grate is. Looks like the igniter is cast into the burner cap?
Actually, they did away with the cast iron center grate. The center is now stainless steel--raised to the same height as the burners grates. The igniter is mounted to the cap, not cast into.
I went to Absolute Appliances and saw it live, cranked it up to feel the heat. The picture is the base model. with vertical vent, no back trim. you can still order 6" or shelf back trim as before.
I called Capital for more information. They said it comes with 3x23KBTU burners and one 8000 BTU simmer burner. Capital said you can order it with upgrade to all 4x23,000 BTU burners
This post was edited by chrls_socal on Thu, Feb 27, 14 at 18:05
this is a close up of the new style of burner / ignition. This makes the burner much more precise so far as the location of the ceramic ignitor and the first set of holes
I was close to choosing to buy the 30" manual clean Culinarian based on seeing the former model (CGMR) with all cast iron grates. Stainless steel between burners seems like a downgrade. I got the same picture from a distributor that Chris_socal posted above, so I am afraid that the new model indeed has substituted stainless steel for cast iron in the middle of the top of the range. Looks unattractive to me and I imagine scratching it with pots. Given some persons' reports of the big burners being less than perfect for simmering in small pots, the small pot or simmer burner seems like an improvement. Question to those who know the Culinarian best (like Trevor Lawson), what if anything is improved in the MCOR model and what is not as good as the CGMR model?
My appliance guy says the MCOR has a lower back guard and the glass cover over the broiler goes away.
The center CAST IRON grate has returned to the MCOR304
Yes, per the company, to get the newest MCOR model with the center cast iron grate:
"Yes, please make sure when purchasing a unit the serial number ends in a letter “C”. The units with the stainless steel in the middle will have a serial number that end in a “B”."
Is anyone who is knowledgeable willing to share an opinion whether the new manual clean model is on balance better or worse than the old CGMR model (which seems to be for sale some places)? Or even whether the simmer burner is a good thing or not (since one can still order with 4 uniform burners if one does not want the simmer or small pot burner)? Is the simmer burner a 23K burner with fewer holes, or is it an 8K burner? Does having a smaller burner make calibrating burners and keeping them calibrated a problem?
Did Capital change anything else when they added back the middle cast iron grate? A spec sheet from October 2013 shows 25K burners not 23K???
FYI for anyone else out there who is shopping for a range, I have been told that the other differences between the old CGMR 304 and the MCOR 304 with the stainless steel strip in the middle are:
MCOR can be installed with vertical gas supply coming out of floor; MCOR has about 33% larger oven capacity and fits a commercial size cookie sheet at the cost of removal of the glass cover from the broiler (so the broiler element gets dirtier, is harder to clean); MCOR has the one 8K small pot or simmer burner; MCOR oven door construction is all stainless steel and glass with flat glass panel instead of porcelain and glass with a 1.5 inch porcelain window pack; the bake (bottom?) oven burner is flush in the MCOR instead of having 1.5 inch high oven bottom cover; flush wire mesh broiler element instead of flush wire mesh under glass; no gas shut off valve on the MCOR; no rear casters on the MCOR; 2 instead of 3 oven racks on the MCOR; MCOR has flush island trim with vertical venting instead of 3 inch island trim with front venting. I think that's all of them.
