Can one install after market variable control on hood?
cheri127
15 years ago
MATERIALSThe Most Popular Roofing Material is Affordable and Easy to Install
Asphalt shingles, the most widely used roof material in the U.S. are reliable and efficient, and may be right for you
Full StoryGREAT HOME PROJECTSHow to Install a Dimmer Switch
New project for a new year: Take control of your lighting to set the right mood for entertaining, dining and work
Full StoryFENCES AND GATESHow to Install a Wood Fence
Gain privacy and separate areas with one of the most economical fencing choices: stained, painted or untreated wood
Full StoryGREAT HOME PROJECTSHow to Install Energy-Efficient Windows
Learn what Energy Star ratings mean, what special license your contractor should have, whether permits are required and more
Full StoryREMODELING GUIDESFinishing Touches: Pro Tricks for Installing Fixtures in Your Tile
Cracked tile, broken drill bits and sloppy-looking fixture installations? Not when you follow these pro tips
Full StoryARTWitness a Fantastic Chihuly Glass Sculpture Installation
Ever wonder what goes into a design that includes a major — and highly breakable — artwork? Here's your chance to find out
Full StoryFLOORSWhat's the Right Wood Floor Installation for You?
Straight, diagonal, chevron, parquet and more. See which floor design is best for your space
Full StoryREMODELING GUIDESRanch House Remodel: Installing the Interior Finishes
Renovation Diary, Part 5: Check in on a Florida remodel as the bamboo flooring is laid, the bathroom tiles are set and more
Full StoryHOME TECHNew TV Remote Controls Promise to Do More — Without the Struggle
Dim your lights, set up user profiles and discover a remote you can't lose. Welcome to the latest and greatest way to change the channel
Full StoryHOME TECHSwitch On the Phone-Controlled Home
Lock your front door from afar, let your thermostat set itself and more when you use your phone as a control device
Full StoryZanesville's Most Skilled & Knowledgeable Home Improvement Specialists
More Discussions
malhgold
cheri127Original Author
Bonita Kitchen & Bathroom Designers · Four Corners Kitchen & Bathroom Designers · Kalamazoo Kitchen & Bathroom Designers · Bensenville Kitchen & Bathroom Designers · Bay Shore Kitchen & Bathroom Remodelers · Calverton Kitchen & Bathroom Remodelers · Garden Grove Kitchen & Bathroom Remodelers · Idaho Falls Kitchen & Bathroom Remodelers · Overland Park Kitchen & Bathroom Remodelers · South Jordan Kitchen & Bathroom Remodelers · Westminster Kitchen & Bathroom Remodelers · Berkeley Heights Cabinets & Cabinetry · Jeffersontown Cabinets & Cabinetry · Plymouth Cabinets & Cabinetry · Riverbank Cabinets & Cabinetryjejvtr
marthavila
guadalupe
sombreuil_mongrel
User
sombreuil_mongrel
kaseki
drtom77
lovelovelovefood
kaseki
