| A question or five from a newbie on range hoods! I have been reading through these forums, gathering everything I could from the ventilation threads. I've read to my level of understanding, and out the other side, and have questions and the hope that some of you might be able to recommend range hoods you have been happy with. We are renovating a first floor kitchen. Right now, the oven (Ge Profile 30" five burner) is in a grandfathered spot that wouldn't even be legal under modern code. It used to have a large microwave over it re-circulating air, but that died a sparky death. So, basically anything we do is going to be an improvement, but I would like to get this right, since we can't do it a second time. We are moving the oven to a safer spot, (Against an outside wall, since it is the first floor, we will have it vent directly out) and putting in a range hood. We only have around 33-34 inches of space to play with under the current plans, I believe, not 36". I have been reading a lot about CFM, and it seems like I could probably get away with anywhere from 400-600 for this type of oven, but would like to double check my understanding of this. Will 400 be enough, or should we eliminate from consideration anything that is not 600? We are hardly the greatest cooks, but we do like to learn, and experiment, and right now, we are regularly setting off the smoke detectors when we cook things on high heat. Opening the windows in winter in New England is not something we enjoy doing. Many of these posts indicate you should try and get a hood slightly bigger than your range, the better to capture smoke and grease. As mentioned above, we don't have a lot of wiggle room -- and I'm not seeing a lot of 33 inch models. Will 30 inches be enough, or just not good enough? Should I push for the design to be changed, to give us more space for a 36 inch hood? (It will mean sacrificing cabinet space, and might not be possible -- it's a small kitchen). Finally, I have been looking at several different brands -- Best by Broan, GE Profile, Faber, and Bosch. Are there any other obvious and wonderful ones you would get, because you have it already and love it, or would buy if you could go back and do it again? These five all seem to get fairly good reviews, and have styles that we like. Budget for the hood can be up to $1,500. Would prefer not to go over that, unless it's the most amazing range hood that ever fell to earth. TIA! |
| Any range hood will be an inprovement over the microwave with indoor vent. When you used the microwave vent, was it sufficient? The microwave was probably only about 300-400 cfm. If you got away with that then I would say 600 is plenty. Since space is a concern I think a 30" wide is also fine. You may want to look for one that is 24" deep. Capture area is important so if the hood is flat on the bottom it will not work as well as one that has a recessed area even if the cfm's are equivalent. You also should think about baffle filter. Baffle filter will give you better air flow and they are easier to clean. |
| Tom2013 -- The microwave was really not sufficient. We still set off the smoke detectors. The point about depth is really useful to know -- I had been looking at a few (Bosch, Broan) that were straight down, and then the flat bottoms -- I think I will adjust to the triangular shaped or rounded/triangle shaped ones I have on my list, since it may be difficult to eke out the space for a 36 inch hood. (We could do 33, but there are very few of them!) |
This post was edited by tickybox on Mon, Feb 4, 13 at 13:07
| Tom-- Just want to make sure I am correctly interpreting what you have to say about the recessed bottom being better. So, we should be looking for one that basically has a lip of some sort all the way around on the bottom with the flat panel recessed a bit rather than one that is flat all of the way across? |
| Needinfo1 - what Tom meant by recessed is a canopy hood. I.e. don't buy one of those flat hoods, even though they look cool. Also, the curved glass ones aren't so great. A canopy hood will capture best the rising smoke and grease. To the OP, a 30" hood will be fine. The hoods that are 36" wide over a 30" hood are the ideal, but so many of us cannot afford to forego the upper cabinetry for the 36" width. You should get a hood that is not a skimpy depth of 20-22". Those won't cover the front burners. As Tom said, a 24" depth hood would be good. Your question about 600 cfm vs. less cfm: it is better to have the 600 cfm, even if you don't use it that often, say, for searing steak, than to have an underpowered hood, and have to have it on its highest setting all the time. You'll have less noise if you can run your 600 cfm hood at medium or low, and still have the hood be effective, than if you are running your 400 cfm hood on high all the time because it is underpowered. Make sure your exhaust duct is sized properly. Most hoods specify an 8" or 10" diameter duct. There are some hoods that allow a 6" diameter duct, but they're harder to find. The problem with pushing too much air through too small of a duct is that you will get increased noise and decreased efficiency though no fault of the hood. So check your exhaust duct size (if already installed), and match your hood to it, or if still in the construction stage, install the right-sized duct. |
| Another brand to consider is Kobe. I have one and like it. Quiet, easy to clean. Baffles, nice capture area. Allows different vent sizes - I think 6, 8 or 10". I got mine from ventingdirect.com. Good prices, good service. If you have a hood delivered to you, be sure to check it for dents or damage before signing for it. I considered Proline hoods, too. They look good. Both Kobe and Proline I only saw on the internet - no distributors in my city. |
| One thing I forgot to mention is mounting height. The higher you mount the hood, the more CFM you will need. I like to lean over the stove so I mounted my hood 33" off of the counter height. As far as the capture area, you will see that many baffle style hoods have the baffles mounted at an angle which leaves a good capture area. |
| Ginny20: It's good to hear about the Kobe. I had actually been looking at the Kobe 9230, because it looks good, and has 760 CFM, but I didn't know what people thought of the company -- it's not one I have heard of before. Unfortunately, it looks like this hood only has a depth of 20 1/2", which is disappointing. akchicago: It is surprisingly hard to find hoods with that depth! But this has helped me to narrow down my search quite a bit. We should be fine on the duct size -- currently, it is non-existent. We are giving up a window in order to move the oven to a safe spot and give it a hood, so we are starting from scratch, and should be able to get the construction right from the beginning. |
| Tickybox - go to the ajmadison website. They have a great sort feature on their website, and you will be able to search for hoods that are 24" wide. Also, you can sort by price low to high, so you can see the ones that fit in your budget. I believe you will see a Broan and a Ventahood that are 30" wide and 24" deep, and come with baffle filters, and there are others besides those two. |
| akchicago: It may have to do with the other conditions I put in, but the options I end up with are very limited, and when I click through the the actual specs, they become more limited (for example, since the filter range originally starts out at 22-24.9, a lot of what looks good at first is really only 22") If you plug in 1) Stainless Steel, 2) 30"-34." wide 3) chimney style, 4) 600-700 cfm and 5) 24"-24.9" -- you end up with only two choices, a Dacor and a Bluestar. If you widen the filter to 22" to 24.9, you come up with a Best that I actually was already considering -- (The WT321302SB) -- which looks great, and has almost every other feature I am looking for -- except the 24 inch depth. Am I over thinking this? I'd like to be able to say looks don't matter compared to function -- but I admit, I'd like this to look attractive as well as doing it's job. *edit for spelling |
This post was edited by tickybox on Tue, Feb 5, 13 at 10:52
| akchicago: and it's occurred to me that perhaps I don't know enough to know what I don't know... when you say go with a canopy hood, over a flat bottom -- does this statement rule out all chimney type hoods? AJ Madison has them as separate categories in their filters. I had been assuming that as long as it still had the triangular shape, rather than simply being sort of curvy, or one of the ones with a flat square bottom attached to the chimney tube, that it still counted as canopy for purposes of capture. Am I running into the depth issue specifically because I have been looking at chimney type hoods? |
| I measured mine. It's 21" from the backsplash to the outer edge. (since my granite BS is 1.25", the whole unit must measure 22") The hobs on my induction cooktop end at 19" from the backslash, so my pots are generally under the hood. Although 24" depth would certainly be preferable, I don't think you have to go nuts to try to get it. |
| Before ordering anything from Proline, one would be well-advised to check out their history with the Better Business Bureau |
Here is a link that might be useful: Proline Range Hoods BBB page
