blue star 36' range hood - minimum coverage?
Posted by victoriajane (My Page) on Tue, Feb 3, 09 at 9:31
| I just did a search on blue star ventilation on this forum...it appears that with such high BTU's, a powerful hood is important but even more important is coverage. Therefore, for a 36" blue star range, the hood should be wider than 36" and deeper than 24", correct? The problem is we only have space for a 36" w hood. (I hadn't been considering the blue star when we designed the kitchen.) Given the dimensions I have to work with, would you abandon the idea of the blue star and go with a wolf or thermador (or something else where none of the burners are more than 15,000?) Or can I compensate for the size of the hood with more cfm? |
RE: blue star 36' range hood - minimum coverage?
| People get crazy with ventilation. The Bluestar hood has teepeed style baffle filters which means it is drawing from both front and back creating a extended capture area. You can choose between 600 or 1200 cfm and they can be top or rear vented. Here is where the problems come in are you getting a grill (BBQ) on the range, how far and how many turns will be in your duct run, can you use 10" duct if not what size duct can you use. |
| Choose a hood that is 27" deep and you should be fine. |
