Tue, Feb 28, 12 at 8:37
| We are putting a range in an island and are wondering if
Corian can be used near these ranges. The range will most likely be a 36" BS or CC. Being that Corian is a synthetic we were wondering if it is suitable for these high heat ranges. |
| So long as the heated gas, air, and cooking effluent rises into a good ventilation system, and hot pans do not overhang the Corian, then the temperature of the Corian at the side of the stove should not exceed the softening temperature of the Corian (about the same as Plexiglass). However, a single mistake of putting a hot pan on it may damage it too deeply to sand out. This can easily happen if one burns himself cooking and drops a pan or metal utensil onto the Corian (for example, as a result of the anti-induction brigade's famed need for flaming bell peppers :). I recommend soapstone, which is relatively impervious to any hot objects likely to be put onto it. kas |
