Tue, Jan 31, 12 at 16:11
| We just purchased a DCS gas range (RGU-366-L). Per the manual, the sump area should be cleaned with a mild detergent. I have found this method ineffective. I assume the warnings regarding harsher cleansers are not really warranted but would appreciate advice from other DCS owners before venturing into unknown territory. Thanks. |
| By the sump area do you mean the cooktop around the burners? I use either Fantastic or if necessary Barkeepers Friend. |
| Yes the area around the burners. Thanks for your advice. I take it there are no ill effects using Barkeeepers Friend.. |
| Barkeepers Friend is terrific - it's great on stainless steel. I think it can't be used on bronze or nickel finishes. |
