HELP - Spill Runs Between Glass on Miele Oven Door
massgirl (
Thu, Jan 29, 09 at 7:43
I see there are a bunch of folks who have Miele ovens, perhaps you can help. After a nasty broiling episode which splattered grease on the oven's glass horrifically, I tried to clean it. In doing so, water solution dripped in-between the glass panes of the oven doors and now you can see the dried water drips through the front. I have self clean, haven't tried it yet on this problem, but I can't imagine how that can help. Anyone ever had this issue?
Thanks for helping me out. |
RE: HELP - Spill Runs Between Glass on Miele Oven Door
| Just got my answer; there is no do it yourself answer. Called Miele tech center and in order to solve this problem a tech has to make a house call to disassemble and clean the glass. Lucky for me they are doing it complimentary because the oven is just over a year old! I guess you have to attack burnt on spills one at a time with miniumum water so it can't get near the edge. |
| I was just reading the other day on I believe the cleaning tips forum. Sounded like several people had success by placing a wet rag on a stick or something and pushing it up through the slots on the bottom of the oven door. Maybe check out over there for more details. |
| Thanks for the suggestion, I don't know if this will work on the Miele oven but I thought it's worth putting up here. Sounds like it's not a common problem, but does happen. |
Here is a link that might be useful: Cleaning Spills Between Oven Door
| I read this post when it was initally posted and have been extremely careful when wiping the glass. However, I had the same thing happen. Apparently liquid - a drop - can go in the slots in the upper part of the door -voila - drip stain. I couldn't believe it as I have been so careful since reading the post. The most I have useds is a well rung out cloth or barely damp paper towel. The service guy says Miele will fix it one time for free. It is a huge design flaw. FWIW the service tech said not to run self clean too often as the high heat is hard on oven ...What??????? I don't know if I believe that - I mean isn't it designed to take the heat? |
| I was told by an appliance sales person that you do not need to use the self-cleaning feature too often...just turn the oven on its highest temperature to burn off "dirt". Hmm. I haven't tried it. I was also told that running the self-cleaning on an oven causes it to deteriorate more "quickly". Whatever that means?! I have no first hand experience either way...just passing along information I received while shopping for appliances. |
| Lucypwd, When the repairman comes to clean the window of your oven, watch him or ask him to show you how you can do it yourself with another person. Yes it will happen again. You take off the oven door (as shown in the use and care book) unscrew the four (?) screws holding the two pieces of oven door together;remove the handle by unscrewing it from the door, CAREFULLY remove the glass sandwiched between the two door pieces and clean the glass. Reverse steps to reassemble. It is not difficult as long as you are working with someone who is handy. Also at the bottom of the oven door there is a large opening which you can use as directed in the link attached. |
Here is a link that might be useful: Cleaning Spills on Glass Between Oven Doors
| Tonight I tried disassembling my Miele Speedoven door to clean a drip between the glass. While taking out the last screw, the outer door crashed to the floor shattering to tiny safety glass pieces. The cost to replace $307, and $189 for service. I had seen the service guy disassemble my regular Miele door to clean a drip while back, and he showed me how to take that door off... doesn't work the same with the Speedoven : ( All I can say is, be very careful. |
| I have a Miele double oven H 398 BP2, and cleaned the glass oven door on the inside as follows: I removed the door per Miele Operating Instructions Manual. I used a wooden yardstick with a long sock on the end. I used dish liquid and warm water on the sock and slide the yardstick (with sock) inside the two pieces of glass. The slots are at the bottom of the door (three openings). The yardstick allowed me to go all the way up to the top of the door, beyond the glass and into the slotted area to wipe everything down. I used clean warm water on the sock (on the yardstick) for a rinse. I used a dry sock on the yardstick to dry between the glass. The glass cleaned up to new condition in about 10 minutes. No technician required. |
Can someone explain how to remove the door of the speedoven? I have the same problem, need to clean the glass... The H4080 manual doesn't explain how to remove the door. |
Bought a Bosch wall oven from Goeman's Appliances to go into my brand new renovated and very expensive kitchen. After 3 uses and only baking some chicken on the middle shelf, to my dismay we noticed the dreaded streak of something between the glass doors. Called Bosch. "Sorry, the warranty doesn't cover this. You will need a service call at your own expense". Called Goeman's customer service, "Sorry, even your extended warranty doesn't cover this. You will need a service call and you will have to pay for it". I am flabbergasted that after spending a fortune on new kitchen appliances, we are now looking at paying for a service call to clean a streak of something from between the glass doors of this oven. I was told that its inevitable that things will get between the glass doors, due to this oven having SEVEN large vents on top of the oven door, and well, that's just too bad...the only way to get the oven clean when this happens is to pay for service calls!! Bullfeathers to that! I will try the coat hanger/wet cloth remedy and post the results. You think you've asked every possible question when buying big ticket items! Who would have known to ask about issues of those stupid vents! |
| Ok..I used a long ruler, a lint-free cloth secured around the ruler with a strong elastic band, and dipped with Windex. My husband removed the oven door and laid it carefully on some soft padding on the floor. I inserted the cloth-wrapped ruler into the opening at the BOTTOM of the door. 30 seconds and the streak was gone. Glad I read the postings on this site! |
