| I found a *most gorgeous* *large* (the image is 24.5x31) hand-colored etching at Goodwill today, by Dan Mitra. WOW. I can't find a pic of it online but it's called "Mallards" and the detail is astounding. I've found some online that are similar - e.g. there's one called "wood ducks" on eBay right now, I think. The birds are even in the same position relative to each other, just on a horizontal orientation rather than vertical. It really should be seen to be appreciated, though -- the eBay pics don't do justice to it in any way.
The only problem is that there are a few dents -- thankfully not on the image, but outside, beyond even where the signature is. Where it would show unless it's matted. No breakage of the paper, but you can see a couple of places where the dear Goodwill folks manhandled it as they wrapped it up with a print to make it a good deal LOLOL... How do I fix those dents? Is there any way? Re-wet the paper? I really want to know if there's any way to do it. I won't do anything until I'm positive it will work, so don't worry. Thanks for any leads! I can find information on repairing oil paintings and adding paper to rips to fix them, but not on repairing dents. |
| It's very common and desirable to mat a print up to the mat line....well actually about 1/2 an inch from that line. Rather than take a chance of nessing up the water coloring...I would mat the print. But I might gently try a steam iron on the wrong side....I might! I think I need to go to your thrift stores!! Linda C |
| Ah, what a good idea -- a steam iron. There are a couple of dents far out toward the edge that I might try that on first. Nowhere near the image. I am always amazed at what I find at my local Goodwills, linda. I'm getting pickier, though. Running out of space! |
| I meant mat it to the plate line....not the mat line.... |
| I figured, linda, don't worry :) thanks again. |
